Outdrive line help
so where and how does it attach back? I don't want it just dangling. It seem the other drive has the same line without the tee just pinched off. Is that the way to fix this? I think my speed-o uses a pickup that looks like a hook under the boat by the plug.
Look for the bolt that holds the front zinc on. The pilot tube hole is about 3 inches rear of that. Stick your hand up in there. You'll feel it. If your not using it. Cut it shorter and plug it off and plug it inside the transom also
