AFR 325 flow sheets.... anyone ever flow these heads?
I have afr 325CC heads, want to see what the REALLY FLOW, not whats advertised.... CNC chamber and bowls, otherwise stock
Take one off and give it to bills dad Tim.
His friend with the cam doctor also has a flow bench and he flows all our stuff.
Very reasonable!
I know he flowed an AFR head some time ago and it didn't flow the numbers advertised. Not sure what head, but it was an out of the box AFR.
Very reasonable!
If you really want to maximize the heads, have Mr. Klein put the full port and blend to them. Have him do the intakes too.
Let bill set them up and have them flowed.
Have you talked to different cam grinders and gotten vastly differing opinions on cam specs? I.E the 108 idea.
not gonna go crazy doing all that, but I feel cams can really help...as far as the 108 thing, came into my head because I did my Ford engine years ago on a 108, ran way better then expected, cam motion cam..Bill told me to do it for more TQ
what would power difference be? don't really need the rpm, but more power, part of the reason for a cam change is I am worried about long term life with these, others have had issues with similar grinds..
All the more reason to take the heads off and evaluate what's been going on and if your worries about the valvetrain are a real concern. You have enough time on the engines that, if the cams are doing damage, you should see evidence by now.
