What would you do for that last few mph >
Old 09-08-2016 | 08:56 AM
From: Central Square & Fishers Landing, 1000 Islands NY
Default What would you do for that last few mph
Everything else being pretty much right (rpms, props, trim/tab settings, etc.) what are the easiest least costly (free) setup tricks you can do to gain a mph or two. I already know the basic free stuff like less passengers, less fuel, get rid of any excess cabin weight like anchors, all of the panties you collected over the summer because it's a Fountain etc. Just curious what your thoughts are.
1000 islander is offline
Old 09-08-2016 | 09:06 AM
Lie about it. Extremely inexpensive solution.
Interceptor is offline
Old 09-08-2016 | 09:10 AM
I have a buddy who does that. He has an old Cig Top Gun that probably weighs 20,000 lbs due to being waterlogged and he's lucky if it goes 65 downhill with a 40 mph tailwind. He tells everyone it goes 100 and it sounds like it does at idle. Maybe he's the smart one.
+1......
Easy for Fountain owners, just do what Reggie did at the factory. Prop it for top speed only, run with 10 gallons of fuel down river/down wind!
Jupiter Sunsation is offline
This one is kinda obvious but make sure there is no chalky film on the bottom
mcprodesign is offline
Old 09-08-2016 | 09:23 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Three of these for your boat:
Three of these for you:
Make sure you eat some beans and hot sauce the night before too.
Sydwayz is offline
Old 09-08-2016 | 09:32 AM
SB
And sand bottom of the boat.?
SB is offline
Old 09-08-2016 | 09:36 AM
Originally Posted by Jupiter Sunsation
+1......
Not true! here is the data from My boats test. Had 120 gallon in it
Attached Thumbnails What would you do for that last few mph-20101118090514270-4.jpg
Old 09-08-2016 | 09:46 AM
Get a KMPH SPEEDO
class6 is offline
Old 09-08-2016 | 10:34 AM
^^^ At my old Jet Ski rental business, I would set speedos to KPH setting. I'd hear " I had it up to 60,bro ,I was flyin' " all the time...
PARASAIL941 is offline
