262ci Modification
1990 Baja 190 DSR
4.3 l merc
alpha one
190hp
looking for some more get up and go.
Edelbrock intake mani
Holley carb
9:1 cr heads and pistons
cam
thru-hull
headers
and of course a new prop.
what do you think of those? how many est. hp?
45ish stock, what do you think top will be after these?
thanks
Tommy
4.3 l merc
alpha one
190hp
Holley carb
cam
thru-hull
headers
thanks
Tommy
yes it was, same flywheel and motor mounts. i know someone with the 350 and i have the same top end as they do and i seem to have better handling. the 350 seems to be too much weight in the boat.
While you have the it apart I would have a machine shop balance the rotating assembly. The 4.3's I rode in all seemed to have a vibration at higher rpms. On a stock engine they will live for a while but in a modified higher rpm engine things could get ugly fast. As far as hp #'s, I would run the desired set up on a desk top dyno and see what kind of hp it will produce. From what people say the desk top can be very accurate. Usually 15 hp gain will result in a 1 mph gain.
