Oil bypass question >
Oil bypass question
Oil bypass question
Old 10-10-2016 | 10:50 AM
Default Oil bypass question
Picked my motor up from the builder saturday. Sounds amazing! I have a question about the oil psi bypass valve.
When i dropped the motor off the oil bypass was plugged. He used a different filter plate to run it on the stand and it had a spring valve in it ( no clue what #). Before dropping the motor back in the boat i swapped them out and put my plugged filter plate back on. Ok?
I tried calling my guy but javnt heard back yet.
cabin fever is offline
Old 10-10-2016 | 12:42 PM
Full Force's Avatar
Better off blocked off bypass then the wrong bypass, I run the 30# ones but many guys use the 11 and have issues... Blocked is fine also then it gaurantees all oil goes through cooler
Full Force is offline
Old 10-10-2016 | 12:56 PM
14 apache's Avatar
Get the racing filter with the bypass built in.
14 apache is offline
Old 10-10-2016 | 12:58 PM
I use the canton racing adapter. less restrictive. Like was said either plug it or use the 30 psi valve.
jeffswav is offline
Old 10-10-2016 | 01:01 PM
Full Force's Avatar
Racing filters don have a bypass..
Well none I know of anyway...
Old 10-10-2016 | 01:08 PM
14 apache's Avatar
You might want to do some research on that there are plenty of them. Some even have screens on the bypass.
Old 10-10-2016 | 01:12 PM
14 apache's Avatar
http://www.wixfilters.com/Speciality/Racing.aspx
Old 10-10-2016 | 01:56 PM
Thanks. Ill leave it plugged then. I run a wix 51060r filter.
Old 10-10-2016 | 02:02 PM
Full Force's Avatar
Ok the ones I use do not have them...
Old 10-10-2016 | 02:47 PM
But remember there is two bypasses,one beside the centre and one below the centre, I took the two out and plugged the one to the right of the centre.
JMPH is offline
