K & N Filter And Cmi Exhaust
IS IT POSIBLE TO PUT THE K&N FILTER SYSTEM AND A LESS RESTRICTIVE EXHAUST ON A 502 MPI WITHOUT CHANGES TO THE CPU SYSTEM WITHOUT HURTING THE ENGINE.
I've done those exact mods and ran to lean send it to Arizona speed and marine I got an oso discount cost me 300 www.azspeed-marine.com
if it isnt running leaner you havent made any more power, if its running to lean you can install an adjustable fuel regulator and bump up the fuel pressure till you get a good reading on your plugs
