LWP to DWP
Old 10-10-2016 | 08:53 PM
Scarab28's Avatar
Default LWP to DWP
Want to convert a LWP lower to DWP. Any helpful hints on doing this mod correctly?
thks
Scarab28 is offline
Old 10-18-2016 | 09:25 AM
Mr Gadgets's Avatar
Charter Member #601
do you want pics with dimensions? I can do that.
Mr Gadgets is offline
Old 10-18-2016 | 09:42 AM
Mr Gadgets's Avatar
Charter Member #601
Looks like I can't edit my post or upload pics to a new post. Shoot me an email and I can send you a pic with the dimensions for where to drill the holes.
Hope that helps.
Dick
Ok.. just doesn't work in IE11. Let me see if I can post the picture..
[ATTACH=CONFIG]560615[/ATTACH]
Looks like Chrome is the answer!
Now you can add as many side holes as you like. The more you add, then you could block some of the lower slots. On the DWP case there are 5 small holes in the nose and the side holes. On the LWP there are large slots. So a balance could be found to accomplish what you want to do.
Hope that helps.
Dick
Old 10-18-2016 | 11:51 AM
thks
This may sound stupid but what the heck are you talking about?
Padraig
Padraig is offline
Old 10-18-2016 | 12:53 PM
Scarab28's Avatar
Thanks Mr. G.
Hope that helps.
Scarab28 is offline
Old 10-18-2016 | 03:19 PM
Trippin's Avatar
FYI....I tried the reverse, I changed my gear-cases from SWP to DWP. Result: I lost speed and it caused cavitation burn on the nose cone of the lowers I presume from a vacuum created during high speed operation, actually caused air to envelope the nose cone and burn the paint off it. Went back to SWP and no more issues. Some boats just weren't designed for a DWP. My .02. I would buy an SEI DWP lower before modifying a good Merc unit.
Trippin is offline
