35 Mistress repower... take 3.... >
Old 11-20-2016 | 08:01 AM
Full Force's Avatar
Default 35 Mistress repower... take 3....
So as most know I have yet to be happy with my builds and found some issues that are causing me to replace cams and do headwork... changing a few other things..overall had a problem free 65 hours on engines but seen wear on cams so I tore things apart..
The parts choices and specs are in a good buddys hands that has mad much success the past 20 years of building, hoping for better results this round as he has never let anyone down on expectations..
The plans include:
existing shortblocks untouched.
Hand port and cleanup of the AFR 325 heads, new valve jobs and new springs, flow heads get real numbers
Port and portmatch new Brodix HV2000 intakes
send old cams back to get replacements and specs TBD still
either going to short travel hydraulic or solid roller this time to get better results that is also TBD
selling Scorpion rockers and going to use Comp or Crower as I can get good pricing
Hoping if I stay HRC I can keep base circle the same and reuse my expensive Trend pushrods.
same carbs 1050 Quickfuel 4150 style
might convert exhaust to dry or find headers that me be following winter of 2017 as this cost is going to add up..
As for results? I would be happy to see at least 1 mph gain over what I had... plan to dyno again if the funds are there to do so... this is my last attempt at this to be what I wanted from beginning... I hope it's worth it since I am fed up with my build situation..
first pic of nice parts lol
[ATTACH=CONFIG]561843[/ATTACH]
Full Force is offline
Old 11-20-2016 | 08:47 AM
Well tim people say third times a charm or some chit like that. U wI'll get it right and both you and frick will have a good 2017. I can feel it
1989mach1 is offline
Old 11-20-2016 | 09:00 AM
Full Force's Avatar
I hope so, I had a good season until I popped that trans... I boated EVERY weekend... but still annoyed at engines even thought no issues yet
Old 11-20-2016 | 09:33 AM
Boats, it`s definitely a love HATE relationship.
Good luck man
ICDEDPPL is offline
Old 11-20-2016 | 09:46 AM
Full Force's Avatar
Thanks Dan, hoping for the best lol
Old 11-20-2016 | 10:22 AM
donzi matt's Avatar
The plans include:
I would imagine if the new cam has similar lift to the old the base circle should stay relatively close to the same so hopefully you can reuse the pushrods. I sincerely hope you get the results you would like this time around, it seems like you are on the right track. Good luck!
donzi matt is offline
Old 11-20-2016 | 02:06 PM
Full Force's Avatar
Thx, I am using a buddy that builds engines with much success to do the work to heads and spec cams, not a salesman lol
I think lift may be similar to keep BC but duration I expect increase a bit for sure.
this nightmare needs to be over.
Old 11-20-2016 | 04:33 PM
Nice intakes Tim. I have the dart intakes they look like they
flow better May have to upgrade.
Cheers RG.
Rick G is offline
Old 11-20-2016 | 05:23 PM
Full Force's Avatar
Thx, these are supposed to be very good intakes, plus the portwork that's being done, I keep trying to not get my hopes up about results...
Cheers RG.
Old 11-20-2016 | 07:17 PM
Good thinking keep your hopes low that way when you have good results it will feel better lol
