Fuel Pressure Guage Hook Up >
Old 10-05-2002 | 10:08 AM
26 CHECKMATE
Default Fuel Pressure Guage Hook Up
This is a dumb question but I cant figure out how to hook up my fuel pressure guage I just bought. I followed the directions and it doesnt work.Has anyone hooked one of these up before? It has 4 terminals on the back, one is marked S and it has a resistor atached to it and the other side of the resistor is attached to a terminal on the opposite side of the guage that terminal has a I next to it right next to it there is a short teminal whick I believe is for the lights the I is right next to it and the fourth terminal is marked with a G which is the ground. Any help with this would be appreciated.
Old 10-05-2002 | 01:14 PM
26 CHECKMATE
CANT ANYBODY HELP??????
Old 10-05-2002 | 01:38 PM
signal, ground and you light (those two are right on the bulb i take it?)
audacity is offline
Old 10-05-2002 | 01:56 PM
26 CHECKMATE
Audacity, no they are seperate from the buld but you can see how they are attached on the back of the guage.
Old 10-05-2002 | 01:58 PM
who makes the gauge???
audacity is offline
Old 10-05-2002 | 02:24 PM
26 CHECKMATE
gaffrig
Old 10-06-2002 | 07:43 AM
only 4 connections???hummm how about 5?....here you go bro:
http://livorsi.com/instructions/GIFP.pdf
audacity is offline
Old 10-07-2002 | 01:13 PM
26 CHECKMATE
Thanks Audacity those are the same directions I got with the guage and they dont make sense. The back of the guage looks different than the directions. I am going to call livorsi today. Thanks for all the help.
Old 10-07-2002 | 07:45 PM
Cignificant's Avatar
Most of gauges I've hooked up work this way..
S = Sender (connect wire that comes from your sender)
I = Ignition (provides power when key is on)
G = Ground
I agree the "short" one should be for your lights.
Cignificant is offline
Old 10-07-2002 | 10:37 PM
OkieTunnel's Avatar
Cignificant is right. S = sender, G = ground, I = ignition. If the light is at the top of the guage, right should be to the light switch and the left terminal on the light should be ground. If it were a mechanical guage it would have a fitting for the pressurized line, Ignition, Ground, Light switch, and ground for light.
OkieTunnel is offline
RedDog382
08-06-2007 09:16 PM
35 White Lightning
Fountain
6
09-06-2005 01:50 PM
BAD-HABIT
9
05-06-2003 03:08 PM
scottsumrall
16
08-20-2002 11:26 PM
fishead
5
04-22-2002 08:03 PM
