Need help with prop >
Need help with prop
Need help with prop
Old 12-16-2016 | 11:34 PM
Default Need help with prop
I have a 28ft Emerald Stiletto with a steptted notch haul an 454 bored 30 over with dart heads an intake Howard's custom grind cam speed pro pistons forged crank erson lifters an bravo 1 outdrive that has a Hydromotive Intimidator Q-IVX Four Blade 23 Pitch RightHand prop on it. Now here's where I'm having trouble I trim down on both motor an tabs get on plane which is about 20mph then start speeding up an once I get to 40mph which is 4,000rpms it's like the prop blows out an just spins an Rpm shoot up to 5,500rpm then I have to slow back down to 40 an that's it please someone help me
Emerald 28 is offline
Old 12-17-2016 | 02:08 PM
Prop hub, Engine coupler, or bravo clutch. or the prop just is real bad
class6 is offline
Old 12-17-2016 | 03:19 PM
F-2 Speedy's Avatar
is this boat new to you ?
F-2 Speedy is offline
Old 12-17-2016 | 03:48 PM
Just reading your post again, 4000rpm at 40mph. you might be just way under propped and breaking it loose. I would do the slip numbers if I were you. something is not right
class6 is offline
Old 12-17-2016 | 04:10 PM
I agree that sounds like the rpm is way high for that speed
1989mach1 is offline
Old 12-17-2016 | 04:13 PM
Brovo1 4 blade 26s might be a good choice for you.
Old 12-17-2016 | 04:20 PM
Yes the boat is new to me I've had it for 6months now.. I've talked to a couple people an they say to put a 5blade 26
Old 12-17-2016 | 04:25 PM
F-2 Speedy's Avatar
At what point in the trim process are you lifting the tabs, why are the tabs necessary ?? have tried it without them getting on plane
Old 12-17-2016 | 04:37 PM
I'm lifting the tabs once on plan an I have to pull the throttle way back so it doesn't over rev the motor.. I use the tabs sense they are there an it helps get on plane a little bit faster.. now I have tired not using them an it takes just a little bit longer for the Front end to come down
Old 12-17-2016 | 06:05 PM
Check the drive and make sure its going all the way down/in and not just going buy the gauge or indicator, then pull the prop off and pull the hub out and take a look
class6 is offline
