Has anyone ever...
has any one ever experienced a 30* increase in oil temp and excessive blow by when switching from synthetic to regular motor oil? Water temp remained the same. Am I just burning off the remains of the synthetic???
Dan
Dan
I switched for several reasons...not available..breaking in new distrib gear..temps were too low.. never got hotter then 200 even when running hard..mostly 150 or so.
Now temp is 230 at 3500-4 rpm
pressure is good
water 150-160.
Also timing was way advanced which would cause hotter temps???? Also may have over filled it...12 qt pan..I put in 12 qts..usually run 10
Backed it down to 35* after a short run. Power is still good. What conserns me is the blow by
pressure is good
water 150-160.
Well
It was the oil I guess
Re placed the Valv with more Royal Purple and all is right with the world again. I cant figure this one out...but who cares???
Thanks for the input fellas
Dan
Dan
