cam suggestion
If you're building a 468 why would you stay with stock exhaust? I would imagine its budget related but at that point you'd be better off staying with stock everything. i don't know the specs on that cam but merc uses some pretty tame cams for the reversion reason. I think the stock 502 mag cam was on a 115.5 LSA. With like .483 lift. You can get a hold of gils or stainless marine for a decent price. Would certainly be worth it
http://www.compcams.com/Company/CC/c...?csid=449&sb=2
I have one in a 439 cid BBC.. it WOULD have reversion with stock exhaust manifolds.....
I was running Eddie Marine manifolds with the long riser option and it worked fine...
https://www.youtube.com/watch?v=2UX0wQBukI8
The exhaust itself isn't going to net the gains. It gives you the ability to add cam to get the gains. Good luck either way.
this is a budget build for me i have a hydrolic roller cam from bob m that my brother gave me and i have set of solid roller lifters from a motor i had before. i was wondering if i can use these lifters with that cam
Slowly put the wrench down and step away from the motor.
You may be the nicest guy in the world with nothing but the best intentions.... However your budget build is about to cost you a lot more money and you will probably have a new hobby before it is all said and done.
