Pulling motors >
Pulling motors
Pulling motors
Old 03-12-2017 | 06:50 PM
Default Pulling motors
I just finished pulling the 2nd motor in my 32 Fever, and have no clue how its all going back together, I pulled them both with the exhaust manifolds on and had a heck of time getting to motor mount bolts. Has anyone here ever done this and how did you reinstall them? also I keep hearing about using the tool to align them when they go in but I don't see anyway for any adjustment with the offshore style mounts??? Any advice is appreciated.
T_traylor1 is offline
Old 03-12-2017 | 06:59 PM
F-2 Speedy's Avatar
Did you pull the drives before removing the engines
F-2 Speedy is offline
Old 03-12-2017 | 07:22 PM
Yes pulled drives first then pulled motor
Old 03-13-2017 | 06:58 AM
They are a bitc h to work on. You may have to go back in without the inside manifolds or any at all. Then they are really fun to install later.
TxHawk is offline
Old 03-13-2017 | 07:06 AM
F-2 Speedy's Avatar
Correct the off shore mounts don't have adjustment, the alignment tool is to make sure the input shaft of the drive and the coupler is at the correct angle if this is a bravo boat
Old 03-13-2017 | 08:13 AM
[ATTACH=CONFIG]565533[/ATTACH][ATTACH=CONFIG]565532[/ATTACH Did you take on to much? I have always pulled off exhaust manifolds first unless the bolts are frozen. Get as much out of the way before you lift the motors out.
Attached Thumbnails Pulling motors-20160915_203654.jpg   Pulling motors-20160915_132749.jpg
fordf350 is offline
Old 03-13-2017 | 08:58 AM
I didn't think there was any adjustment, so in a perfect world it should just go right back together I suppose
Old 03-13-2017 | 08:59 AM
Yea those inside motor mounts look fun, as does installing the manifolds in the boat...
Old 03-13-2017 | 09:08 AM
F-2 Speedy's Avatar
there should of been fiber washers between the inner transom plate and the bellhousing, just make sure it goes back in that way
Old 03-13-2017 | 09:27 AM
Pulled mine in my 32 a few times, Get a longer punch to run thru the holes of the motor mount & off shore bracket. Gives you the ability to move the motor pretty easily & run a bolt thru. Find someone with really long arms or someone short & skinny to able to lay down. Mine had aluminum brackets on the stringers to be able to stand or lay on if you can get down there. Tape those fiber washers to bell housing too. I always left the exhaust on.
jmoore1225 is offline
