T Bolt Clamps >
T Bolt Clamps
T Bolt Clamps
Old 04-19-2017 | 02:13 PM
Default T Bolt Clamps
I thought T bolt clamps were better then worm clamps and they would last longer. So far two of these have broken the same way. Appears to be metal fatigue. It came off my 08 truck but same things are used on boats. Was thinking of replacing them on the boat but after two I'm having second thoughts.
[ATTACH=CONFIG]566505[/ATTACH]
AllDodge is offline
Old 04-19-2017 | 03:16 PM
VoodooRob's Avatar
Depends on the brand. We use T-Bolt clamps in manufacturing of motorcycle exhausts. Five Star or Breeze have worked very well for us. Have tried many others, nothing seems to work as good or lasts as long.
VoodooRob is offline
Old 04-19-2017 | 03:26 PM
J-Bonz's Avatar
Rob, any thoughts on RG Ray or Clampco out of wadsworth?
J-Bonz is offline
Old 04-19-2017 | 03:31 PM
Things that bother me is most worm clamps start to leak a bit, but these just break all at ones. The crack is very small in nature, don't know if I would have noticed with regular inspections
AllDodge is offline
Old 04-19-2017 | 03:37 PM
VoodooRob's Avatar
Have not compared those on our applications, Clampco has been marketing Marine T-Clamps, is that the brand AllDodge has in the above photos?
Old 04-19-2017 | 04:46 PM
No, these are Mopar/Chrysler but its just that how can you tell when there going to fail.
AllDodge is offline
Old 04-19-2017 | 09:50 PM
VoodooRob's Avatar
What size you need I can send you some, I know a guy
Old 04-20-2017 | 07:09 AM
Appreciate that, but already replaced all of them on my truck with ones from NAPA. Guess if I do go the route on the boat I'll contact you. Have only had a couple problems with the worm clamps and there always the ones that get removed every so often for maintenance.
AllDodge is offline
Old 04-20-2017 | 08:55 AM
I have been using them on all my many boat's exhaust for years. I do get mine from a local hydraulic shop. The one thing I do not like about them is the the T bolt or nut seems to strip out pretty easy. Never going on, always taking off.
f_inscreenname is offline
Old 04-20-2017 | 09:27 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I've never seen them break line that. Interesting. I messed one up royally (threads) a while back when replacing the trim indicator cables. I bought a cheapy from Advance Auto to hold me over that rusted immediately but still held the drive indicator on just fine. I replaced it with some I bought from Amazon and I thought they were great quality. To my knowledge (boat now sold) they are still fine. Just my experience.
Sydwayz is offline
