Tranny slipping
Old 07-04-2017 | 10:01 AM
tripps's Avatar
Default Tranny slipping
Got boat out finally been sitting for 15 years,its a 23 cat w trs. And 330 Hp 454 ran 4900 rpm wit,slow, then went into netrul,then it moves until 2000 rpm then slips, looks like a 71 or 72 i no it has to come out ,any ideas ???
tripps is offline
Old 07-04-2017 | 10:56 AM
assuming you have a solid hub prop? If not maybe prop hub went south? I know it's kind of a stretch but worth checking before you pull engine & trans...
offshore312 is offline
Old 07-04-2017 | 04:21 PM
You didn't say, but did you change the trans fluid?
mike38scarab is offline
Old 07-04-2017 | 09:45 PM
Tranny fluid will usually smell burned if their bad enough to be slipping. You sure it's a Borg-Warner trans and not a MercTrans. Should have a metal tag on it.
picklenjim is offline
Old 07-05-2017 | 05:50 PM
Is there a band to adjust too, or am I thinking of the merctrans? And is it just for reverse? You can download borg repair manuals free all over the web.
dereknkathy is offline
Old 07-20-2017 | 05:32 PM
If you need new transmissions, I have a nice set of 72-C Green Tags with TRS tail stocks. Let me know if you're interested.
endeavour32 is offline
