KOdiak 225 90* Line Fitting Size?
Does anyone know the thread pitch and size (both sides) of the 90* brake line fitting that screws into the caliper?
I couldn't get the 90* out of the old unit (boogered it up) and a used caliper I bought didn't have one installed.
Thanks for any help you can lend!
Keith
Keith
I'm away right now to check but I believe the fitting is 1/8" npt and 3/16" inverted flare. The fitting also has a restrictor hole in it. I have an extra one that I removed from my old caliper I can send you when I get home if you can't find one.
Keith
Verify, but this one looks to be it:
Replacement Kodiak Brass Adapter Port for Disc Brake Calipers
Keith
Anyway, if trying to go local, 1/8" NPT to 3/16" FIF 90* fitting.
3/16" FIF = 3/16" female inverted flare
Inverted flare is very common.
Not your link, the one I pured from.
