Are MEFI 1 Marine and Auto Units Swappable? >
Old 10-22-2017 | 06:41 PM
Default Are MEFI 1 Marine and Auto Units Swappable?
Engine's are '96 MerCruiser 7.4 LX Mpi's. I'm having erratic idling issues as discussed in this thread Help Chasing Erratic Idle Please
I ATTEMPTED to swap the ECU's today and happened upon MEFI 1's with two different Model numbers, #16234539 and #16189069. See attached picture, they are different sizes. I stopped right there as I'm not sure whether or not they are swap-able. The #162 was used by Mercruiser the #161 was not and seems to be a GM car/truck ECU (see attached picture from MEFI Burn). So now I have more questions than answers.
Should the Non-Mercruiser unit (#161) even be on a boat? Did modifications to sensors, harness, tune etc. need to be made to use in on my marine engine? I was afraid of swapping them and potentially cause more harm than good.
https://uniim1.shutterfly.com/ng/ser...714842/enhance
https://uniim1.shutterfly.com/ng/ser...714862/enhance
Thanks for any insight you can lend.
Keith
Tractionless is offline
Old 10-22-2017 | 10:27 PM
The 16189069 WAS used by Merc. That is the OEM unit on my 95 Merc motor. Still using it today. You should be able to swap them.
Trash is offline
Old 10-23-2017 | 05:59 AM
I would check the sensor plugs between engines and compare them to see if they are the same and then put in the correct unit.
Warship2k15 is offline
Old 10-23-2017 | 11:22 AM
10-4 exactly the same. As far as I can see the engine harness' are identical.
Keith
Old 10-23-2017 | 12:00 PM
But is the tune the same? Fuel-ignition curves.
dereknkathy is offline
Old 10-23-2017 | 12:44 PM
Considering MEFI stands for Marine Electronic Fuel Injection, I doubt it came off a car.
Griff is offline
Old 10-23-2017 | 01:25 PM
To answer the above and for the archives, I called MEFI Burn today with the issue. They stated any of the model numbers listed in the picture in post #1 will work but as Derek eluded to they must have the correct tune installed. MB also stated the MEFI's were used in other platforms other than the marine industry. If I have purchase another unit I'll need to ensure its loaded with the proper mapping for my engine, no matter what the model number.
Atleast I now know I can swap side to side and see if my issue goes away.
Keith
Old 10-24-2017 | 12:23 AM
The GM ramjet motors and others used the MEFI controller.
Trash is offline
Old 10-24-2017 | 12:25 AM
Keith
The tunes between the motors should be identical assuming they haven't been fiddled with. If it comes down to installing a replacement ECU just copy one file and transfer it to the the new unit.
Trash is offline
Old 10-24-2017 | 01:21 AM
I understand that, but its not used in any production automobiles. .
Griff is offline
