Scorpion 4014 roller rockers on 496. >
Old 12-18-2017 | 02:40 PM
Default Scorpion 4014 roller rockers on 496.
Hi Guys.
Hope you can help me out here.
Do any of you guys know if the 4014 Scorpion roller rockers with the arp 135-7201 studs will fit under the stock valvecovers on my 496 MAG HO.
Regards.
Jens henrik.
jens henrik is offline
Old 12-18-2017 | 03:13 PM
Are you doing springs also
class6 is offline
Old 12-18-2017 | 03:18 PM
No, just the rockers if they will fit under the stock valvecovers.
Old 12-18-2017 | 06:16 PM
I have a few HOs, Whats your reason for the rockers?
and yes they will fit
class6 is offline
Old 12-19-2017 | 12:56 AM
I have converted my 496 mag into a 496 mag Ho and installed a set af Stainless marine manifolds aswell. I have a set of 4014 Scorpion roller rockers i will install, just to beef up my valve train, but only If they will fit under my standard valve covers. Will they be plug and play??
Old 12-19-2017 | 06:02 AM
I planned to do this exact setup a year or so back. Called Scorpion and asked the same question. They replied it "SHOULD" fit under stock valve covers. I did not want to be the test dummy or have to cut down the polylocks. I purchased a set of Raylar's rockers and AFN nuts proven to fit under stock covers. Must further add that valvetrain geometry is spot on with their setup on the stock guideplates and studs.
Ryan00TJ is offline
Old 12-19-2017 | 07:45 AM
Thanks Ryan.
I would like to know for sure, cause If they dont fit i will skip the projekt.
Old 12-20-2017 | 07:17 AM
Anyone else done this??
Old 12-20-2017 | 06:14 PM
Originally Posted by jens henrik
Thanks Ryan.
No problem. I was in your same situation. class6 stated in an earlier post that they will fit. Might want to contact him for sure. I could never get a 100% for sure answer.
Ryan00TJ is offline
Old 12-21-2017 | 06:11 AM
Why does everybody use polylocks? The stock style jam nuts are just as strong and stay put. Polylocks are for constant lash adjustment with solids. And the poly's are what stick up so high.
dereknkathy is offline
