292 Fastech Nose Cones, and Props >
Old 02-15-2018 | 12:02 PM
Default 292 Fastech Nose Cones, and Props
I have a new to me 292 Fastech with the 377 Scorpions and was going to repaint the drives. I thought about putting nose cones on it while I had them off but was wondering if anyone else had tried them before and with what results. Also curious if there is a benefit with spinning the props in?
Thanks in advance!
soonenough is offline
Old 02-17-2018 | 06:17 AM
I wasn’t going to respond as I have no experience with a 292, but since no one else s giving you feedback, here goes..
How fast is your boat?
I’m not an expert, but I dont think you would see anything good from nosecones on your boat. I dont think they have any positive benefit until you’re over 80 and may have a negative impact if you can’t reach that speed.
Generally, props spinning in will suck in the stern (lift the bow) and give you more speed. However, you’re going to lose handling ability around docks. I tried mine turning in. The boat ran better, but it was not worth the loss of manuoverability around the docks to me.
Hope this helps.
Apexwarrior is offline
Old 02-17-2018 | 04:22 PM
Thank you for the reply.
The boat runs right at 80 now with the current set up. I was hoping it would pick up a few MPH with those two changes.
Old 02-17-2018 | 05:53 PM
I know of a couple boats running a tick over 100 with stock lowers, I had hyromotives on mine, took them off because they epoxy was coming off, ran the boat, picked up about 2 mph in cruise speed, basically due to the removal of the additional surface area, and made no difference on top end
JaayTeee is offline
Old 02-18-2018 | 06:30 AM
I would talk to Bblades about your props. If you haven’t had them labbed yet, they can probably
work them to get you a few extra mph.
