Running 496 on a stand >
Old 03-02-2018 | 05:01 PM
Default Running 496 on a stand
I want to run my 496 engine in the workshop out of the boat.
can someone tell me the wiring i need to run to the 10 pin plug
AusScarab29 is offline
Old 03-02-2018 | 05:10 PM
F-2 Speedy's Avatar
I wired mine to a key switch like this......
F-2 Speedy is offline
Old 03-02-2018 | 08:53 PM
Service Switch from CDI , works awesome , helps with diagnostics also.
dunnitagain is offline
Old 03-03-2018 | 03:10 AM
Thanks so the big/fat red wire and the black wire are the power to the ecu .and the thin red wire is the key/ switch
Old 03-03-2018 | 09:31 AM
F-2 Speedy's Avatar
you need to hook the battery - to the block and the battery + to the starter, which will provide +12vdc on the pin where the large red wire is, this will connect to the center post of the switch, then the switched +12 will return on the smaller red wire thats connected through the plug to the starter relay, your ecm, alternator, ect should be powered off the other wires connected to the + starter terminal where the battery connects.
Old 03-03-2018 | 03:38 PM
Thanks,what is the black wire in the switch for
Old 03-03-2018 | 04:32 PM
F-2 Speedy's Avatar
Do you want me to come start it too...............pin 5 is coil...........mine are carb on EFI
Old 03-04-2018 | 12:36 AM
Thumbs up
Oh I have a 10 pin plug and fuel injection,I need to run power to the ECU this then controls the eight coils.
Thanks for the offer of coming over and starting my engine,cant yet I am still in the middle of a major rebuild.
Thanks for your help
