87 Baja 240 sport Prop question. >
Old 03-20-2018 | 09:11 PM
Default 87 Baja 240 sport Prop question.
I have an 87 240 sport, with a 496 stroker putting down about 550hp. I’m swapping the alpha for a bravo 1, but I got a smokin deal on a 1.36 gear ratio. Does anyone know what prop I should start with?
Bigjohnbaja is offline
Old 03-20-2018 | 10:13 PM
23mirage 3 blade. Or a 22p bravo 4 blade. Depending on what rpm you’re looking to turn. Being that far in the basement with the propshaft the 3 blade will be the faster prop and 4 blade will cruise better but could porpoise.
mickeymcclgn is offline
Old 03-21-2018 | 01:10 AM
/\/\/\/\/\/\/\/\/\ What he said
I could spin a 23 Mirage + to 5450 with about 420hp on my 93 24 Outlaw with a 1.5.
With your additional HP, you should be close to the right WOT rpm with the 1.36.
Griff is offline
Old 03-25-2018 | 04:39 PM
Thanks guys for the input. I will try it and let you know how it goes.
Old 03-25-2018 | 05:34 PM
I had 1992 24 outlaw 502 390 hp 1.5 gear 25 pitch 3 blade mirage. 5000 rpm 68 -70 mph. Liked that boat. 24 degree, trailered nice, fast and efficient
https://photos.app.goo.gl/uAwqBtCL39LUVMXh2
veloc410 is offline
Old 03-25-2018 | 05:36 PM
veloc410 is offline
Old 03-27-2018 | 01:45 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Our 23 OB/FX 4 blade would be a good candidate. These props have a ton of bow lift built into them.
Get a baseline with whatever prop you can find and post the results and we can go from there.
1.36 gears from 1.50 gears require down sizing about 2 inches of pitch.
Brett
[email protected]
bbladesprops is offline
Old 03-28-2018 | 08:54 AM
Thanks Brett. I appreciate your input. I see your name mentioned a lot. I will be in touch with you
Old 04-01-2018 | 08:45 PM
I would add a 21 or 23" Rev 4 in the mix as well. Due to the larger blade area a 21" Rev 4 will load the motor like a 23" Mirage. A 23" Rev 4 will load the motor like a 25" Mirage etc. Slip, trim and handling characteristics will be much different between the two styles.
Trash is offline
