Winterizing problem and GRW impeller update... >
Old 10-21-2002 | 10:46 PM
Bill272's Avatar
Default Winterizing problem and GRW impeller update...
Well I started to winterize yesterday and Stbd motor went just fine. Swapped the muffs, turned on the water and fired up the port motor. I picked up some stuff in the boat, started cleaning out the glove box while it warmed up and went back to check things out. At that point I noticed I had NO water coming from the exhaust!!! It had been running for maybe 5 minutes like that, and the temp gauge was showing around 160. The exhaust was hot, but not too hot to touch.
I pulled off the intake hose and cranked up the hose and water was flowing thru the drive. Then I pulled the water pump to check out the impeller. 5 minutes running dry and it was fine. Someone had asked in another post if they take on a set, and it had taken a bit of a set, probably no more than a merc replacement. I'll be working on it tomorrow to figure what went wrong, but I thought I'd give an update on how the GRW blue impeller was holding up. They claim that they can run for 15 minutes dry, but I don't think I'll try that...
Bill272 is offline
Old 10-22-2002 | 06:39 PM
mopower's Avatar
Toxic FORMULA
Cool Thanks
mopower is offline
Old 10-22-2002 | 09:04 PM
Vinny P's Avatar
I hate the winter!!
Where are you guys getting GRW Blue Impellers from??
Vinny P is offline
Old 10-22-2002 | 09:47 PM
Bill272's Avatar
I got mine from www.boatfix.com.
http://www.boatfix.com/bymfg.ASP?mak...+WORKS%2C+INC.
Bill272 is offline
Old 10-23-2002 | 07:46 PM
Vinny P's Avatar
I hate the winter!!
Thanks Bill....
Vinny P is offline
Clay Washington
Cigarette
37
09-29-2007 02:45 PM
hp500efi
9
07-03-2007 11:08 AM
Mr Gadgets
3
05-08-2006 08:08 AM
timucin
25
12-05-2003 12:00 AM
Erie Desire
Baja
0
10-10-2002 12:41 PM
