24 (22)x7 X-dim >
24 (22)x7 X-dim
24 (22)x7 X-dim
Old 04-08-2018 | 08:45 PM
Default 24 (22)x7 X-dim
I was at 15 7/8" Has any one ran 18" how did it work out?? Getting ready to cut...
phragle is offline
Old 04-09-2018 | 06:55 PM
cannot believe there has been no feedback on a 24 7 x dimension.
what boat is this, the one from the guess how fast it'll go thread ?
outonsafari is offline
Old 04-09-2018 | 07:09 PM
Yep...major time setbacks but the new motor should be lit off next week, the glass work is done, just need to cut a hole....
phragle is offline
Old 04-09-2018 | 08:03 PM
I went with 18.5" X on my 26' Corsa..
ran GREAT. !
Boatally Insane is offline
Old 04-09-2018 | 09:22 PM
ran GREAT. !
No problems planning or blowing out??
phragle is offline
Old 04-10-2018 | 05:54 AM
When Planning. , Always go with the grain and be sure your blade is sharp. Use bathroom before planning to avoid Blowouts
tommymonza is offline
Old 04-10-2018 | 05:57 AM
Proper planning will avoid blowouts before going on Plane. And avoid seats near babies, even if their mommies are Hot.
Old 04-10-2018 | 04:09 PM
Nope.. NO issues planing running 4 blade props.
One season it had a 454 mag in it, I built out of scrap.. It Knocked, but ran 68 MPH with a 26 Bravo I lol
The Only issue it had was when I originally had the tabs mounted parallel to the hull, the stern would skate sideways when trying to correct a list.. Not sure if my high X was a contributing factor or not.. I ended up re-mounting the tabs flat and it worked GREAT...
I did put my 555 in it without the blower for a bit.. ran 86 MPH (630 hp)
Old 04-11-2018 | 06:14 PM
My 22' Avanti was set at 16.19" from the factory I think but it's tough to measure accurately with the small curved "delta pad". I plan on raising mine this coming winter if all goes as planned. From everything I've read on here in the past it sounds like Pantera recommended 17 but then Thomas had his mounted at 18ish and it worked great with certain props. I plan on cutting mine at 18.5 and then spacing down if needed. Post some pics when you're done please.....I'm curious to see how the transom looks when its finished
mbobb is offline
Old 04-11-2018 | 06:22 PM
Here's how mine looks now......I went with a 3" taller exhaust last year since I hated how low the original exhaust was. You can see I still have height to move everything up a few more inches with the +3" risers
mbobb is offline
