ARP head studs  525 EFI >
Old 04-10-2018 | 05:33 PM
F-2 Speedy's Avatar
Default ARP head studs 525 EFI
anyone have a part # for the Mercury 525 EFI with the Edelbrock alum heads
stud kit not bolts
F-2 Speedy is offline
Old 04-12-2018 | 08:48 AM
TomFTM's Avatar
I dont have the part number for the studs, but I do have a set of cometic head gaskets for standard bore 525 efi, part number c5760-40 , I put one of them on the block (block honed .005 larger) and saw that it was too close to the cylinder bore size , the other is still in the package(untouched) . Both are in original package . I went larger bore on the gasket. I will sell them for $150 including shipping . Tom
TomFTM is offline
Old 04-12-2018 | 08:55 AM
i am pretty sure it would be the same as a gm iron head,why do you want to use studs?
mike tkach is offline
Old 04-12-2018 | 09:01 AM
F-2 Speedy's Avatar
thanks Tom, I just bought two sets
Mike T....blowers are going to be installed, I just prefer studs over bolts
Old 04-12-2018 | 09:45 AM
F-2 Speedy's Avatar
I found a old OSO post that states they use the same bolt kit as the Brodix heads ?? part # 135-3609 this true ?
Old 04-12-2018 | 09:51 AM
That is correct.
Young Performance is offline
Old 04-12-2018 | 09:59 AM
F-2 Speedy's Avatar
Originally Posted by Young Performance
That is correct.
thanks
