Char-Lynn angled shims >
Old 04-26-2018 | 07:05 AM
Default Char-Lynn angled shims
Looking for the angled bezel or angle cut aluminum shins that adjust the helm to dash relationship. I know there old school but I don’t have 1K for a tilt column! Thanks.
Btrhd is offline
Old 04-26-2018 | 07:53 AM
F-2 Speedy's Avatar
Are these the horse shoe shaped shims that go in the auto steering column
F-2 Speedy is online now
Old 04-26-2018 | 08:29 AM
Sounds like they would work. Two are needed (one one each side of the dash) so the bolts go into the helm straight. Any pics of what you have?
Btrhd is offline
Old 04-26-2018 | 08:35 AM
F-2 Speedy's Avatar
I'll check when I get home, I think I have a couple in a old cooler full of auto parts I've been dragging around for 30 yrs
You may want to check with McMaster Carr also,
Old 04-26-2018 | 09:04 AM
Sick Stinger's Avatar
Brotherhood #1
There is a guy in MI who's will machine anything you need. Name
os Derrick. I have his contact info. He is a member here also.
Sick Stinger is offline
Old 04-26-2018 | 01:13 PM
I had to make one. Machined for the front and just glassed in a wood wedge on the back. To get something like 10* it adds 3" to the thickness of the dash, so you may need a spacer for the steering shaft also. I will see if i can find a pic of the spacer for you.
justintocars is offline
Old 04-27-2018 | 10:53 AM
thanks to all, the more info the better!
Btrhd is offline
Old 04-29-2018 | 10:05 PM
had one made by a local guy to me. Top notch general machinist. Very reasonable, just tell him the angle you want and he will make it. The blue one was a 8* wedge that I had laying around that I gave to him for a guide. PM me if you want his contact info.
mickeymcclgn is offline
Old 04-29-2018 | 11:17 PM
I screwed it to the bottom of my existing shim....
You can kinda see the line on the bottom where the shim is attached
