Hydromotive p5 25p
Old 05-20-2018 | 06:41 PM
Default Hydromotive p5 25p
5 blade hydro prop,25 pitch, no damage, gonna be to small for new combo. $400 shipped call or text 386-837-7035
Bnbz28 is offline
Old 06-05-2018 | 09:00 PM
Will the prop fit 1.25 prop shaft?
SutphenSteph is offline
Old 06-05-2018 | 09:14 PM
I believe it will fit both. If you swap the hubs
Bnbz28 is offline
Old 06-05-2018 | 09:25 PM
im pretty sure hydros are a fixed hub.. looks like it from the pix as well.
freekazoid is offline
Old 06-05-2018 | 09:54 PM
Second pic shows the hub removed
Bnbz28 is offline
Old 06-06-2018 | 08:02 AM
It is interchangeable from big to small. I currently have the small hub for it.
Bnbz28 is offline
Old 06-06-2018 | 05:56 PM
so if you look at the back side of the prop that hole determines what size shaft it will accept. unless the inner sleeve is removable it is a fixed hub.
Old 06-06-2018 | 08:53 PM
Like i said it is interchangable.....
Bnbz28 is offline
Old 06-06-2018 | 09:10 PM
Freek, all you need is a new 1.25 Merc Hub. The newer a Hydromotive props use the Merc hubs.
Bnbz, how did it run on your 280 Velocity? What engine?
padraig
Padraig is offline
Old 06-06-2018 | 09:19 PM
padraig
just bought this one it had a 548 in it but needed a lot of help, previous owner put the motor together and cam timing was off 2 teeth lol. Only ran 68mph. That motor is out and the new 598 should be done in the next few weeks, boat should run between 100-105 mph. Had a 280 from 2001-2011 with a 650horse motor that ran a best of 95.3. This will make about 100horse more than that one
Bnbz28 is offline
