TBI on a bbc marine application. Bad idea? >
Old 05-21-2018 | 12:31 PM
Default TBI on a bbc marine application. Bad idea?
I was gearing up to try the Sniper system on my 509 with air gap intake but heard that the single carb on a bbc is bad enough at distributing the mixture as it is, but a TBI with its finer atomization compounds the problem. Approx 550hp. Any real world experience on this?
Baja Rooster is offline
Old 05-21-2018 | 09:29 PM
I can't comment on the fuel distribution issue, but have helped an individual with a BBC and bored out big injector TBI. Ran fine but pulled vacuum at WOT due to insufficient air flow. This even with the bigger bore TBI. Cam and heads were very mild too.
Trash is offline
Old 05-21-2018 | 10:58 PM
Ah, that makes sense. Now that you’ve mentioned it it seems that I heard that too. Thanks.
Old 05-22-2018 | 06:12 AM
run 2 or 3 tbi's,problem solved.
sutphen 30 is offline
Old 05-22-2018 | 07:24 AM
I have always wanted to try and run two TBI's on a dual 4 barrel intake.
You would have to be experienced with tuning, or know someone that is.
My stock 5.7 EFI Merc has the big block TBI on it. They adapted it to a tiny 2 barrel intake. We will see if it still has vacuum at wide open throttle on my 383. If it does maybe next year I will try and run two of them.
Paxtonspeed is offline
Old 05-22-2018 | 11:45 AM
Don’t use a dual plane intake manifold.
hogie roll is offline
Old 05-22-2018 | 11:46 AM
Lol. So I’m ignorant on the Tech, but what’s so different between the Merc TB on the Merc MPI and a 4 barrel TBI? Is it the huge plenum or the lack of fuel thingamajiggers in the venturies?
Old 05-22-2018 | 08:09 PM
There were several variants of EFI on Merc motors so the nomenclature is causing confusion. Around 1994 the Merc EFI motors began in ernest, with the 350/454/502 Mag EFI/MP. Those motors had a dual stage progressive throttle body with 8 individual port (hence the Multi Port name) injectors. In addition a little lower in the line were the TBI motors, which were the two barrel 'carb looking' throttle body with a large injector in each bore. After that things changed drastically as some throttle bodies became large mono blade pieces with port injection etc. I don't know of any 4 barrel style TBI Merc motor. There might be one, but I quit following all the nuances a while ago.
Trash is offline
Old 05-23-2018 | 12:02 AM
So this is a project/Topic i have a special interest in and have been doing tons of research on it. I'm a firm believer that EFI is far superior to a carb any day and all day. but i can save that lecture for a different day.
thread i have started on it
EFI Stock TBI maps for a 350
gear head EFI will have stock truck bin files and the matching .xdf files
for a stock merc 260hp 350Cu.in motor the 2x 1-11/16" should be fine.
The unmodded TBI units should be (i can post the math if needed)
5.7L SBC 2x 1-11/16" ~=490 CFM
7.4L BBC 2x 2" ~= 645 CFM
a 350 @55000 @ 0.85 VE =~474 CFM
No such thing as zero vacuum at WOT in a NA engine. Each piston on it's downward stroke with intake valve open, creates vacuum to pull the intake charge in. Equal pressure on both sides of intake manifold creates NO air movement, it's physics.
Holly assumes a 1.5" pressure drop across the carb, so you should not see "0" vacuum.
you can run it on a dual plane, you just need a spacer or a way of balancing the vacuum pulses between the plans ( milling or cutting the interior wall)
Engine Masters ran into the issue you were talking about.
KeatonAZ is offline
Old 05-23-2018 | 05:10 AM
scarabman's Avatar
My Innovation 540 CI 600HP engines had Holley TBI and they were GREAT!
scarabman is offline
