How long did your exhaust flappers last? >
Old 05-27-2018 | 03:39 PM
Default How long did your exhaust flappers last?
I had a pair of teague inner "butterfly" style flappers that maybe lasted 40 hours off of some dry pipes. I'm not sure if they were welded or riveted in place. Does everybody's inner flappers blow apart after short time? Is there a more secure way to mount these inside flappers...? Weld vs rivet?
gofast_wilder is offline
Old 05-27-2018 | 03:53 PM
GPM
The heat of the dry pipes may have something to do with it.
GPM is offline
Old 05-27-2018 | 04:08 PM
Both flapper mounts are there, but I only have half a rubber in one of the pipes. I wonder if there are inner steel flappers? I could put high temp silicone on the edges so they don't make a "clatter" sound, since I usually here about the rubber on the outside of steel flappers peeling off.
Old 05-27-2018 | 04:26 PM
GPM
That's the heat doing that. There used to be companies making the steel flappers, not sure any more. Maybe check CP Performance.
GPM is offline
