Water dumps
Old 07-23-2018 | 09:16 AM
Default Water dumps
I have a warlock 25 sxt with a carb 502.i have to much water presure.I put 2 dumps off the rear of the intake with values to controll the flow but the motor dosnt get enough water to the thermostate.where is the best place to put my dumps.Thanks.
warlocky is offline
Old 07-23-2018 | 02:43 PM
Put an adjustable pressure relief valve in the main water supply hose.
Griff is offline
Old 07-23-2018 | 03:36 PM
Here’s what you need.
payuppsucker is offline
Old 07-23-2018 | 04:01 PM
Wher did you get them and where do you install them at.
warlocky is offline
Old 07-23-2018 | 04:07 PM
Hardin Marine or CP Performance. I prefer to put them in the hose that goes from the oil cooler to the motor so you get full flow through the oil cooler.
Old 07-23-2018 | 04:24 PM
SB
Smart.
Merc racing suggests to put there's and all water psi regulators after the oil cooler but before the block..
SB is offline
Old 07-23-2018 | 04:48 PM
vintage chromoly's Avatar
I put mine before the oil cooler, but I’ve never dumped any water. Mine runs at around 12PSI
vintage chromoly is offline
Old 07-23-2018 | 05:13 PM
GPM
Did you always have to much pressure or is something restricting the exit path of the water, block or exhaust manifolds full of rust or dirt.
GPM is offline
Old 07-23-2018 | 05:15 PM
You are obviously not running a thermostat.....correct?
Old 07-23-2018 | 05:17 PM
I run a thermostat.
