1986 242ls 260/alpha to BB/Bravo, have questions. >
Old 08-08-2018 | 01:30 PM
Default 1986 242ls 260/alpha to BB/Bravo, have questions.
When switching from a 260/alpha to a BB/bravo 1 are the motor mounts the same? I know about the 2 extra holes for the Bravo. Will the stock alpha throttle /shift cables work? How does the alignment work? Will the stock 260 harness work on a 90s BB? Both are carbs.
any/all tips and tricks is appreciated.
Alwhite00 is offline
Old 08-08-2018 | 04:19 PM
Motor Mounts the same
The '86 uses the old style ends on the cables, so maybe. You need to change the shift plate to a Bravo, slightly different swing on arm and no interrupter switch, so you may need to change that cable (shift).
You need an alignment tool, available from ebay about $ 30
Should, there are 2 connectors I am thinking a 9 pin and a 10 pin. Your boat has the 9 pin, if your new motor has the 10 pin, you can remove the motor side connector from your 260 and put it on the 454 and that will work.
Good luck, don't go stock 454 or you will be very sorry very soon.
For the misc parts you need check with OSO member Sick Stinger, he is very helpful with these parts at a reasonable price, he also has motors for sale at a price you cannot build one for.
GLENAMY 242SS is offline
Old 08-08-2018 | 07:40 PM
Thanks for the info. What would this run with a stock 454/B1? The 260 works fine, just would like a little more speed. Yes it's all stock. If it works out I will have under $2300 into the drivetrain. Thought for that it may be worth it.
Old 08-08-2018 | 08:02 PM
Yes a LITTLE more speed is what you will get
Old 08-08-2018 | 09:52 PM
ok, I give - what can I reasonably expect going to a B.B./B1?
Old 08-09-2018 | 07:05 AM
Old 08-09-2018 | 07:40 AM
TomZ's Avatar
Exhaust tip location might be off. If using stock exhaust with long hoses, that won’t be an issue. But if you use aftermarket exhaust it could create some problems with exhaust tip alignment.
454... a stock non-mag 330 engine is going to give you low 50’s, high 40’s dependent on load. The 365 mag will get you around 55. If you have a mag, then you have a good foundation to build from.
TomZ is offline
Old 08-09-2018 | 08:07 AM
It's not a mag. If it was low 50's that would be gaining me 10mph. How much heavier is the BB/B1? I like how the boat sets in the water with the SB
Old 08-09-2018 | 08:38 AM
TomZ's Avatar
You’re going to add about 300-350 pounds to the stern. The small block package with the drive is about 900. The. If block package will be over 1200.
TomZ is offline
Old 08-09-2018 | 08:39 AM
TomZ's Avatar
In my opinion the boat will look better sitting in the water with a little more squat.
TomZ is offline
