Keith Eickert mechanical fuel pump issues
Finally got the new motor fired and started tuning a little and found that I only am showing 4-5 psi fuel pressure...it is the fuel pump mounted on the water pump style and I have the Keith Eickert fuel pump "upgrade" that replaces the head of the stock pump
What pressure should I be seeing at idle and WOT?? I thought I should see 7 psi all the time with this pump especially at idle
I have 1/2 inch pickups in the tank to -8 an lines to the imco tank selector valve to a hardin FST filter to the pump then out to the carbs...all lines are -8 an up to the carb where they are hardlined from the fuel distribution block to the carbs
Any ideas?? anyone experience this before??
thanks
Stewart
thanks
Stewart
The psi is set in the lower part I believe.
I ran that pump many years ago. I think 6psi is what I saw ? I really can't remember exactly. Sorry. If you have no less than 5psi at WOT I believe you are fine.
I was seeing 4-5 idle and it dropped to as low as 2 at cruise.....never made it to WOT as that scared me with fuel pressure that low and didn't want to chance a lean condition...I have far too much coin in this motor to melt it down hahaha
when you say pressure is set in the lower part...could you elaborate?? nothing at all came in the box with this thing as far as instructions or anything so I'm kinda shooting from the hip....are you saying that pressure is adjustable on these?? I thought they were a bolt on and go kind of thing???
thanks
thanks
thanks
Stewart
thanks
Stewart
well sh!t hahaha hopefully I find something else wrong as these are literally 2 hours of runtime old lol
what are you planning on running if you get rid of the KE's?? Staying mechanical or going electric??
