Detent
Old 09-02-2018 | 09:07 AM
Default Detent
Went to launch the other day and my bravo 1 wouldn’t go into reverse. Having not gotten the cover off yet because couldn’t loosen drain screws. I believe I have the tool for that. Went and bought the fattest widest screw driver. My question is not knowing what I’m going to find. How often is it the cover wobbled out or is it just the spring and ball? And when I have the cover off can I shift to reverse to check ease in movement? Anything else I need to watch for.? Thanks
Force265 is offline
Old 09-02-2018 | 02:09 PM
But based on your other post, the engine was not running. Bravos should not be shifted when engine is not running
Griff is online now
Old 09-06-2018 | 07:33 PM
blue thunder's Avatar
Detent wont have anything to do with not going into reverse. Check shifter linkage first. Remove shift cable coming from helm at the shifter bracketand shift drive forward and reverse while engine is running to eliminate cable problems. If it still wont shift move to back cap inspection.
blue thunder is offline
