Alternative Engine
Old 09-04-2018 | 05:22 PM
Default Alternative Engine
hey guys,
Ive got an old 2jz-ge engine(Toyota Supra) laying around and I was toying with the idea of replacing the 5.7 Chevy that’s in my boat with it.
I’ve built and tuned these motors before and I can get to about 500hp at the crank for around $1k so it’s cheap hp.
So at the surface it seems like a cool idea but I know there’s got to be more to it so I’m hoping you guys can tell me why I shouldn’t do it.
As far as dimensions, it’s only one inch longer than the SBC. I would have to switch to through hull exhaust and it would be a dry exhaust system so I know there’s going to be other things affected by the heat. What would be some of those issues? Can the SEI alpha one drive or the flywheel be adapted to a different engine?
This probably isnt the most practical idea but I’d appreciate you guys indulging me here a bit.
Cheers 🍻
Romeomikehotel is offline
Old 09-04-2018 | 07:26 PM
I know nothing about the conversion, but you should try if you can
2JZ-GE Hydroplane
noli is offline
Old 09-04-2018 | 07:27 PM
noli is offline
Old 09-04-2018 | 07:42 PM
Look up PSI Racing Eliminator Daytona. Really cool boat. Lots of vids on YouTube.
CJSYD is offline
Old 09-04-2018 | 07:45 PM
Search the boards here- there was an OSO member that marinized a couple of these motors.
Powerquest230 is offline
Old 09-04-2018 | 08:10 PM
SB
Yes, same boat person with post just above you mentioned.
SB is offline
Old 09-04-2018 | 08:26 PM
You had me thinking it was doable, untill you mentioned putting 500 hp thru an alpha.....
phragle is offline
Old 09-05-2018 | 09:02 AM
doesnt have to be 500, boost can always be turned down. that’s just about the highest I could get and still be under $1k.
But you bring up a good point. What’s the power limit for an alpha? Is the alpha the deal breaker that makes this a useless project?
Old 09-05-2018 | 09:59 AM
phughes69's Avatar
Merc recommends 300 HP with a alpha. I think back in the day they had a 320 HP SBC hooked to a Alpha in the Formulas
phughes69 is offline
Old 09-05-2018 | 12:48 PM
back in the day, they also put alpha drives behind BBC's in Sea Ray 32 Pachanga's, 33 Donzi's, and a hand full of others. Seeing as how that trend (or the drives) didn't last long they quit the BBC & Alpha combo...
offshore312 is offline
