Preparing cylinder heads for marine application
Apart from valve material, and I guess valve seat width are there many other things to look out for. I can't see why you would have to run larger valve guide clearance but could be wrong!!
How you you prep a street head for marine use?
Valve guide clearance in many cases wont have enough clearance. .0015/.0017 int-.0018/.0020 exh. Depends on build, hp, NA, SC. Severe duty SS int valves min and inconel exh, manganese bronze guides, good hardened seats, and if aluminum ideally should be dielectric coated but personal preference and if your in fresh or salt.
Definately want to consult with a good reputable head guy who knows marine.
I shan't be doing that just ....bolting them on, we have a great workshop and can carry out most of the work, I've been trying to find a valve seat face ratio but can't find one anywhere. But will measure the valve to guide clearance for sure.
Crude Int correct with his statement on seat material and good advice. I would imagine there are endless ductile seats getting hammered around the boating world without issues however CI is correct. I know I ran for years in Darts without issues but not any real high hp builds. Not to today's standards anyway.
Back to your heads.... What are they? Valve degree seat valve angles vary but basic old school build would be a 45/30 from what I remember. Sounds like you have limited sources.
The guides are Manganese Bronze and the seat are also Powder Metal which gives me good bones to start with.
I've just purchased a Rottler 3 angle cutting tool I'm not sure what valve seat width we will have until I cut a test piece, but I think I'm going to shoot for 5% of the valve diameter. We do have engine builders here in Nova Scotia but they are more reman stock engines, plus I like to keep as much work inhouse as I can and learn from the process. Thanks for all the pointers to date
