Closed cooling BBC
The ravages of salt water boating has me thinking "closed cooling" but not much to choose from for a 572 tall deck EFI engine........anybody doing or has done?
Looking myself right now for a tall deck . CP Performance has a set up , I talked to Russ at Mr. Cool , he said a ""off engine " exchanger , I never seen a set up like that in a boat bilge . I would like a full FWC system . You looking for a full or half system?
https://aftermarket.monitorpro.com/p...-kits/mfh-5374 - This is a system from MONITOR I was looking at but the exchanger is 5 1/8 x 22 , don't know if that is big enough for SM manifolds.
https://www.cpperformance.com/p-7979...per-brass.aspx - exchanger is 5 x 33 looking at install diagram
My alternator is on Starboard side not lower Port and I'm not altering the serpentine system. CP system as well says 9.8 deck , and brackets made to mount exchanger to front of heads , again , on my engine the serpentine brackets utilize those holes on heads.
Full system........just spent $5,500 for a pair of Imco powerflow manifolds and risers and I know to well how salt attacks aluminum
