Straight Bottom Top Gun TRS Prop? >
Old 01-23-2019 | 04:07 PM
Default Straight Bottom Top Gun TRS Prop?
Looking for input on props on a TRS Top Gun with straight bottom and 500hp motors. Pitch? 3 blade? 4 blade? Pros and cons
YoungGunKC is offline
Old 01-23-2019 | 04:37 PM
F-2 Speedy's Avatar
I ran 28 4 blade on my 92 Kevlar boat but it was 625 a side, whats on it currently
F-2 Speedy is offline
Old 01-23-2019 | 05:30 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Depending on your goals, 4 or 5 blades.
We have propellers from Mercury as well as BBLADES you can test through our test program without having to purchase the propellers.
I like the 4-SPEED BBLADES props since the X dimension is low.
Brett
[email protected]
bbladesprops is offline
Old 01-23-2019 | 06:11 PM
28 3 blades. Only got a couple hours of run time last season (new to me boat). I can’t recall speeds/rpm of the top of my head. But 70-72mph was about max. Very slow out of the hole but seemed to cruise around 48-50 @ 4000, but don’t quote me.
Old 01-23-2019 | 06:27 PM
F-2 Speedy's Avatar
seem like pretty decent numbers, does it cavitate out of the hole ? I did have another 92 TG with 500 EFI's and it ran about the same as your's
Old 01-23-2019 | 06:47 PM
Yeah it cavitates pretty easy if you’re not slow on the throttles. Would a 4 blade help with that?
Old 01-23-2019 | 06:56 PM
F-2 Speedy's Avatar
I tucked the drives all the way and never used the tabs leave them neutral,
Old 01-23-2019 | 08:02 PM
<div style="text-align:left;"><br /><br />Yeah it cavitates pretty easy if you’re not slow on the throttles. Would a 4 blade help with that?</div>
<br /><br />YoungGunKC<br />
Yes the 4 blades will help in that scenario. There aren't too many 28 3 blade props for TRS drives or alpha/Bravo drives. Maybe those props are reworked or adjusted?<br />Your cruise speed efficiency is poor at around 30% slip.<br />Once you get some WOT speed and rpm numbers, it will be easier to get you to the point you want to be at, or the best that rig can be at.<br />The boat is new to you so it makes sense to get a bunch of seat time and performance number that are accurate. Then determine the best route to go. <br />Anyway you look at, a TG Cig is a awesome ride.<br />Let me know if we can offer any help.<br /><br />Brett
I'm not sure why this posted this way but I think you can still manage to make it out..
[email protected]
Last edited by bbladesprops; 01-23-2019 at 08:18 PM. Reason: Software issues with OSO. not sure why the text cam out this way. Tried to re do but didn't work
Old 01-24-2019 | 09:06 PM
Thsy are 25p 3 blades. Idk why I thought 28
Old 01-25-2019 | 10:11 AM
cigrocket's Avatar
I'd say the speed is correct for 500's. As for the cavitation, Like F-2 Speedy said .tuck the drives all the way and no need for tabs. More importantly is initial hooked up speed and boat attitude to plane with the TRS and 3 Blades. I personally wouldn't change the props. Speed # seems right on. Have to see what RPM's you are turning at 72MPH. I will assume 5200-5300 which would be right on. 3 Blades are less stress on the TRS drives. Even though the horsepower is only 500, might as well not work drives too hard with Shock. Enjoy the boat
cigrocket is offline
