525sc
Old 03-27-2019 | 08:14 PM
Default 525sc
Here’s what I got, a set of 525sc’s, one rebuilt 30 hours ago, other with a rebuilt blower. Stock heads were heavily ported.
Want to kick them up, chillers abd pulleys for sure. I keep reading on converting to roller cams, what camis everyone putting in these?
Thinking pull them apart, check out, add a little bit and then not worry about them (I guess that’s everyones goal haha!)
tmmii is offline
Old 03-27-2019 | 08:57 PM
I put the 731 in mine, haven't ran it in the boat but it ran like an ape on the dyno..... This was playing with different pullys
phragle is offline
Old 03-27-2019 | 09:13 PM
731 is a bad *****. Is that with chiller? 625 or so? Pic is blurry on phone.
tmmii is offline
Old 03-27-2019 | 09:18 PM
no chiller but alum heads,,731, 6 psi boost, we spun it harder and made 640 on one pull. the black is 4 pounds,,,
phragle is offline
Old 03-28-2019 | 01:54 AM
I also went with a Crane 731 when I did the top end on my old 525SC. I ran about 7.5# of boost with no chiller.
Finding smaller pulleys to fit the Merc 177 splined shafts is nearly impossible anymore.
Griff is offline
Old 03-28-2019 | 06:01 AM
I got lucky, mine has been rebuilt with the keyed shaft
phragle is offline
Old 03-28-2019 | 06:35 AM
resurrected's Avatar
There has been some smokin' deals on chillers for the 177 in the swap shop section. Right after I bought new ones
resurrected is offline
Old 03-28-2019 | 08:02 AM
does anyone have any more info on this? Where to get that shaft?
tmmii is offline
Old 03-29-2019 | 09:24 AM
Jim Diesel's Avatar
"Unregistered Gun"
Maybe check with The Blower Shop!
How much horsepower could you make out of the 525SC before changing to a bigger SC, could 700 hp be capable out of the 177 with the right heads, valvetrain, and pistons? I have also wondered if anyone has ever converted over to an EFI setup? Reason I ask is I have a pair of 525SC in my boat, I keep getting the bug to have a pair of 700-725 HP engines. I like the idea of keeping the 177 setup and improving it, but I also keep looking at switching to a Whipple EFI setup with good heads and a strong rotating assembly.
Jim Diesel is offline
Old 03-29-2019 | 09:34 AM
I just did mine, 454 with roller cam, 177 blower and chiller, Sniper EFI
File Type: pdf
