When you trailer long distances what all do you bring? >
Old 04-09-2019 | 06:18 PM
Default When you trailer long distances what all do you bring?
Im thinking of adding a trailer box with the following-
bottle jack
random pieces of 2x4 and 4x4
hammer
4 way wrench
spare hub with bearings so if something happens it could save a day of waiting for parts.
Also thinking two spare tires. I like to run at night so tires should have better luck, but if something happens it’s still good to have another back up.
What else should I be packing?
tmmii is offline
Old 04-09-2019 | 06:20 PM
J-Bonz's Avatar
The title should be changed to "Paging Sydwaz"..... He always has good input on this topic...
J-Bonz is offline
Old 04-09-2019 | 06:52 PM
cigrocket's Avatar
A heavy duty floor Jack. 2 Full Hubs ready to go. My Milwaukee impact. A file, grease. I also always have full tool set in the truck box. grease gun. These are some of the highlights. I also like some extra ratchet straps, temperature sensor gun too.
cigrocket is offline
Old 04-09-2019 | 08:25 PM
seafordguy's Avatar
Take two spares!! When we had a blowout at 2AM on I95 it wasn't a good feeling carrying on with no spare.
Chains and hooks to Jack up an axle if needed, laser temp gun, spare blocks of wood for jacking. Take the right size socket and a breaker bar. Those 4-way out wrenches are amateur hour and depending on the trailer wheel you need a low profile socket (my 5-star trailer rims need a low profile socket).
4-leaf clover
seafordguy is offline
Old 04-09-2019 | 08:36 PM
One of those point and click temp guns,,,,everytime you stop for gas, eat, piss, scratch your nutz etc... shoot the caps, hubs and treads. Its a good way to find a problem before it becomes one.
Also make sure you have the correct jack. I discoverd after one trip that the bottle jack I took was too tall to fit under the axle and too short to get the wheel off the ground when used on the beam.....
phragle is offline
Old 04-10-2019 | 12:47 AM
Along with a lot of stuff that others have mentioned, I carry a spare leaf spring and all the bolts to replace it. I've broken a couple of the rear ones.
The parts are only $35-40 and you can't just stop at the auto parts store and get one.
Griff is offline
Old 04-10-2019 | 06:01 AM
badmonkey's Avatar
Everything you can think of take.... especially floor jack, blocks, and a Milwaukee impact.....
badmonkey is offline
Old 04-10-2019 | 06:08 AM
resurrected's Avatar
Flashlight too
resurrected is offline
Old 04-10-2019 | 06:35 AM
Jim Diesel's Avatar
"Unregistered Gun"
Exactly!! The more you take, the less of a chance of needing it!! haha
I take:
Floor jack, jack Stands, assortment of blocks/boards
Spare tires, hub, spindle also spare set of bearing/races/seals
Hammer and assortment of punches
Grease gun, bearing packer, tube of grease
Tail/Turn light and marker light, wire and crimp connectors
Assortment of tools, impact, bearing race driver set
Small assortment of nuts, bolts, hose clamps, ratchet straps, zip ties
Brake Fluid, rags, carb cleaner
Jim Diesel is offline
Old 04-10-2019 | 06:53 AM
Anyone know where I can buy stainless boxes like this?
JRider is offline
