Slow starter - BBC >
Slow starter - BBC
Slow starter - BBC
Old 05-01-2019 | 04:50 AM
Default Slow starter - BBC
i recently rebuilt my engine with higher compression and now need to address the slow crank issue.
Have any of you worked on this and have a recommendation to solve it? Shorter, thicker cables? Gear reduced marine starter (is one avail?)
thank you
sandslot is offline
Old 05-01-2019 | 07:42 AM
I'm having the same issue, looking forward to the replies.
Ryan
Ballistic Beak is offline
Old 05-01-2019 | 08:39 AM
14 apache's Avatar
Bad starter or battery or bad cable or connection not to be funny you need to go in there with volt meter.
14 apache is offline
Old 05-01-2019 | 08:45 AM
Ok, so if the starter and battery are production and 100%, it should turn over a production Mercruiser as well as a 10:1 Mercruiser? I say this because both starter and battery worked well with the standard Mercruiser
sandslot is offline
Old 05-01-2019 | 09:01 AM
Agreed.
OP look up how to do a voltage drop test. Perform it with the ignition coil disabled.
SS496 is offline
Old 05-01-2019 | 09:02 AM
14 apache's Avatar
Put a meter on each cable se what voltage loss you have. Standard starter should work. You can try adding pos cable direct to battery. Double check all ground cables
Old 05-01-2019 | 07:35 PM
Thanks for the feedback.... sounds like a standard starter will work. I am replacing both positive and negative cables with 1 AWG gauge copper wire. Will report back
sandslot is offline
Old 05-01-2019 | 08:48 PM
14 apache's Avatar
Price out the difference doing it 1/0 solder the ends and make sure you have a good battery switch. Spend the extra money find good tinned cable look on eBay.
Old 05-01-2019 | 09:16 PM
are you using a gm mini starter?those starters will spin over most anything.
sutphen 30 is offline
Old 05-02-2019 | 04:50 AM
Yes, I am using your gym starter. I appreciate the comments above regarding the cable as well. I will pick some up and solder the ends and minimize the links overall. I’ll report back
sandslot is offline
