1996 26 Scarab 454mag issues and experiences.
Hey guys, I figured I'd start a thread about my boat and motor issues that I've had and continue to have. My hope (or dream) is that eventually everything gets sorted and I can enjoy my boat again. I welcome constructive advice and opinions as I am kinda nooby with all of this. This thread should also serve as a reminder for my self of things done and things that still need addressed.
So I have a 1996 26ft wellcraft scarab 454mag efi that I bought for what I thought was a great deal last year in March. It is my first boat and I bought it without a sea test as it was too cold and I was too hasty. A compression test was performed and passed and the motor was started briefly and sounded good at idle. The surveyor said the boat itself was in remarkable condition with very little moisture to be found anywhere on the boat. Then it was topped off with the seller saying it was "perfect turn key" so I eagerly pulled out a stack of greenbacks and bought it. On its maiden voyage last year I got an engine alarm and had to get it towed back to the launch. I got in touch with a friend of mine who is a boater and also a licensed auto tech to go though it and once it warmed up it started knocking, it sounded deep in the crank case so we pulled it. Long story short- once we dropped the pan we found that the motor was nuked so I purchased a newly rebuilt longblock and had my friend dress and install it. Once it was installed and after finally getting it running last year it was discovered to have a massive oil leak (1-2 qts or so per hour). My tech friend lives far away and had already spent many hours getting frustrated with it, so I took it to the shop where I purchased the longblock for them to diagnose and fix. Three weeks and $1500 later and it had shiny new oil lines and still a massive oil leak. At that point there was only a couple weekends left of the Michigan summer so I just kept oil filled before during and after every run, disconnected the bilge pump so I didn't pollute, and drained the bilge oil/water into a bucket after every run. Then when the year was over it was shrink-wrapped and winterized. I did still somehow have a decent summer on Lake St Claire with it even though I only have about 20 hours on it.
This year last week I took it to the launch and had a reputable boat mechanic check it out. The motor is leaking from the valve covers and the dipstick tube when under load. Excessive blowby was suggested as a possibility and I'm waiting for a leak down test to be performed Friday. I'm really hoping the motor doesn't have to be pulled again but at this point it's getting hard to think positive. Aside from the oil leak it hisses like crazy from the IAC which I've heard mixed opinions about, and it leaves soot all over my transom after about 1/2 hour run time which I've also got mixed opinions about. The idle is a little choppy but not bad, and performance seems on par with what a 454 mag should provide. It planes easy and tops out mid 60s @5200rpm (non-gps) or at least it did last year.
Other non-related issues that need addressed are the Bennett trim tab pumps leak and the Bennett hatch cylinders are painfully slow. My fuel and speedo gauges stopped working and the transducer for the gps/fish/depth finder got ripped off. (Sigh)
What kind of ventilation do you have for the crank case ? do the valve covers have breathers in them, thats a lot oil the push out of an engine, sounds like posibly the rings didnt seat on the newly rebuilt longblock
Unfortunately, there will be 10-20 threads just like yours this years as there is every year. Bought boats with a piece of schit motor. Too many people that are scum out there.
Arcticfriends (Paul Smith), give him a shout. he's in MI...I know, big state. The injectors should be gone thru when everything taken apart again and he services those too.He know these MPI engines more than most. May be too late to get it done for this summer too, but who knows until you call.
