TRS Starters Grinding
Last weekend one of my starters was showing signs of being on the way out the door. I could get the engine started, but it was grinding pretty badly. It definitely seemed to be a bad starter. After all it had been on the boat for 31 years... time for a new one and while at it I thought it would be a good tome to replace both.
I ordered a set set of starters from DB Electric (have had great luck with them in the past) and went to install the new ones today.
Both grind when hitting the key. I double checked and the starters are flush against the flywheel housing and tight. After a few hits, the starboard one seems to be better but sounds tight (seems like a lot of draw). The port side after trying ten times made the sound once (couldn’t duplicate in front of the Mrs).
I didn’t think there was a shimming procedure for these starters... bolt and go. Am I missing something? I tried searching via Google and didn’t find anything.
Any advice?
Any advice?
Or the PMG260 mini style ?
They are the huge by huge GM starters.. 25 lbs each I’d say.
There is a provision for a bracket on the back of the starter, but no brackets (never seen any).
The starters seem to be exact replacements for what I took off.
https://www.mercruiserparts.com/bam/...y/31808/961/10
The flywheel housing is a 88 420 TRS B/W 72c.
I’m assuming the starters are original, but there are no brackets. Not even sure of where the bracket bolts to from the starter.
