Oil filter attached to valve covers LEAK
Hello all, I use to have an account here when I was a bit younger but cannot for the life of me remember what the info was. I am located in Port Clinton Ohio and do all of my boating on Lake Erie, about a month ago, I picked up an 87 24 Pantera with a 400 small block. The boat is far from perfect however it runs out very well, I have put over 20 hours on her so far this past month and to be honest they are pretty hard hours. I cruise around 4000 rpm, to put me right around 50 mph, motor redlines at 5k.
Anyway, this pump, or whatever it is, started spewing oil out the filter this past weekend. When under load, I lost 1 quart of oil at 3,000 rpm during a 5 minute test run. I should add, 3,000 rpm was all the boat would give me, it could barely even plane off because as I throttled up I could only see about 2,000 until it planed. I am not a mechanic, and am not use to an engine like this. What I am wondering, is any reasons why this could be happening, what part this is, and what steps I should take to replace it.
The part is a metal cylinder with 2 hoses that attach to the valve covers. The metal cylinder has small springs inside and on top a filter is attached. The leak is coming directly from the filter of this unit.
A buddy of mine said just bypass this unit entirely and close the valve covers, not sure if that would.be the safest thing?? It has made an absolute mess of my engine compartment, everything is soaked in oil, granted, I own a detailing company, and this isn't the worst thing ever. Still very frustrating. Any help or advice would be greatly appreciated. Thanks in advance guys.
pics would help greatly....im picturing a common log to vent crank case gasses but im not 100% sure what it is you actually have there.....most valve cover vents should be going to the air filter/flame arrestor to recirculate the gasses back into the motor....
you need 10 posts to put up pictures so you can just post 4 more times with a count down in each posting.
-Wally
-Wally
Ah OK...thats a catch can with a breather....should really only be used on a car since you are potentially venting un-burnt combustion gasses into the engine compartment of the boat. I would start by looking under the valve covers as to why the oil is getting forced out them to this point...is there sludge under there causing the oil to back up and out? is there a baffle missing under the valve cover that should be keeping the oil from getting out? Maybe a leak-down test is in order on the motor? Possible you have too much blow-by causing the crank case to be pressurized and blowing the oil out....
-Wally
-Wally
On a "normal" boat setup you would have those hoses coming from the valve covers and attached to the flame arrestor where it would suck the unburned gasses back into the motor. If you are seeing smoke almost as soon as you start it up id say the rings on the pistons are seized or the cyl walls are scored and you have excessive blow-by getting past the rings and into the crank case. i would do a leak down test on that motor and see how things are sealing......sounds like its got ALOT of blowby!! see the pics i attached...if you look at the air cleaner (flame arrestor) you will two hoses coming up and attaching to it...those are the same hoses coming off the valve covers...that's how it "should" be setup. And you should make getting a bilge blower a priority as well!!!
-Wally
-Wally
oh and yes that catch can should be empty...its really designed more to trap the oil mist that normally would get sucked back into the engine...on a car where your engine compartment has tons a fresh air going around it you can vent it under the hood...on a boat where heavier gas fumes collect at the bottom of the boats bilge...you are asking for trouble!
-Wally
-Wally
