CMI headers and Sealant >
Old 07-31-2019 | 06:17 PM
Default CMI headers and Sealant
Is it a no no to use sealant on the flange between header and tailpipe?? If its acceptable, RTV Red??
Thanks... new to the forum but have been stalking for a while!!!
Kryptonite is offline
Old 07-31-2019 | 06:25 PM
14 apache's Avatar
You can try to let it set before running. That's the only thing stellings uses.
14 apache is offline
Old 07-31-2019 | 06:40 PM
F-2 Speedy's Avatar
rope seal or compression thin gasket ??
F-2 Speedy is online now
Old 07-31-2019 | 07:02 PM
Compression Thin gasket. V-clamp and T Bolt
Old 07-31-2019 | 07:04 PM
F-2 Speedy's Avatar
Ive never used it on the v clamp
Old 07-31-2019 | 07:09 PM
Re-assembing and 1 flange marries up perfect and 1 is a little off. T bolt was a bit rusty on that side so Im assuming it leaked alittle. Prior owner definitely used something on it from the looks of the gasket. Whats lesser of 2 evils, doubling gasket or Hi Temp red??
Old 07-31-2019 | 07:16 PM
F-2 Speedy's Avatar
the tails have to be aligned perfectly inorder not to have a leak......Id use sealant and not 2 gaskests
Old 07-31-2019 | 07:27 PM
Thanks Speedy
Old 07-31-2019 | 08:01 PM
14 apache's Avatar
One thing might be going on if this is twin engine they could have two pipes or two headers switched.
Old 07-31-2019 | 08:05 PM
single.
