O2 Sensor question >
O2 Sensor question
O2 Sensor question
Old 08-13-2019 | 11:04 AM
Default O2 Sensor question
Are any of you that run Holley HP EFI having a hard time with O2 sensor longevity? I was wondering if the moisture from Headers is killing my sensor.
Cerberus66 is offline
Old 08-13-2019 | 11:17 AM
This guy has worked wonders for me.
EVIL ENERGY O2 Oxygen Sensor Bung M18x1.5 Copper https://www.amazon.com/dp/B07G81XZZT/ref=cm_sw_r_cp_api_i_yjUuDbNF6YSVJ
Baja Rooster is offline
Old 08-13-2019 | 02:42 PM
so you had this issue then? can you elaborate a little more on the issues you had?
Old 08-13-2019 | 03:36 PM
LS1
There will always be moisture in a marine exhaust, the moisture/condensation will ultimately render the o2 sensor useless over time and you will have to replace them once in a while. Keep a spare with you. Or use an o2 bung as recommended by Baja above that will make it harder for the moisture to reach the o2 sensor.
LS1 is offline
Old 08-13-2019 | 07:46 PM
Rookie's Avatar
Are you running the NTK sensors? I was told that they work better in the marine environment.
These help also.
https://www.ebay.com/itm/INNOVATE-MO...gAAOSwhglTx8Y0
Rookie is offline
Old 08-13-2019 | 09:09 PM
No I’m not yet. I’m replacing with Bosch and will get a bing extension and see how that does first. I was told same thing by my tuner. They are 100 more per unit and last a little longer.
Old 08-13-2019 | 10:47 PM
These help also.
This is the piece I would recommend too. Made no difference in AFR readings either. I did back to back comparison.
Trash is offline
Old 08-14-2019 | 10:26 AM
I never had any issues to begin with, but have always ran the Innovative bung extender from day one on my wideband.
When i put fuel injection on I got the 90° one that I listed as it’s pretty much the same but the bend allowed me to clock it so the sensor is way up away from the water. 50 or so hours so far and no issues.
Old 08-14-2019 | 12:13 PM
Just for more data I run that extender as well and have about 250 hrs of run time on the same O2 sensor.
Trash is offline
Old 08-14-2019 | 01:28 PM
thanks guys, Ill be doing the same now. new O2 is on a slow truck from holley to me.............
