454 Mag MPI gen v rebuild help
It looks like i have a new winter project. I need to rebuild my gen v 454 mag mpi. i have a few things I want to do while Im in there but the purpose of this thread is see if there is a good kit for marine engines instead of using Merc stuff and maybe to discuss pro's and con's of adding a bigger cam. Minus machinist work Id like to find a complete rebuild kit. I think I ll need main rod and cam bearing, oil pump, marine gasket kit, piston rings, cam and lifters stock vs bigger?, timing chain, and that should be everything. Im hoping ot hear from someone that has rebuilt there and have gotten reliability out of it. I dont want to put cheap parts in it but I want it reliable. My main goal is to cruise, maybe ski, and short full throttle burst. Probably need a crank but if I can have it turned and put in oversized bearing I probably will.
Ive seen so many "marine cams" that supposedly replace the stock cam but does it really? Anyone else know a good cam to replace stock? If Im going stock I dont want to do computer work because the cam isnt just right. If Im going to upgrade I can expect to do computer work but reliability and other work may be needed. Wouldn't mind having something that sounds better. Either way I believe the cam will need to be replaced as some of the lifters had heat spots and with the RPMS believe its probably best.
I have a great machinist that is very cheap so if i can get away with spending $1000 on all parts and machine work vs $2500 for performance upgrade and have to worry about fuel and reliability Ill take the cheaper option.
cb,
Most of the internal parts are no different than a GM truck engine. The parts are all readily available aftermarket and very good quality. Gaskets are definitely different but Fel-Pro makes very good marine gasket sets. Your machine shop should be able to get you a complete kit with everything you need in it.
Not sure how "cheap" your machine shop is going to be but That figure would not even come close to touching the machine work on most marine engines I see with any kind of hours on them. If you need a crank they are $900 from GM and if you regrind yours it will be $250. Then you need some rods by the sounds of it, they are $100 a piece. And so it goes. If the block needs boring an engine kit with pistons and just a stock camshaft will probably be in the $700 range.
You get the picture
You get the picture
If you're trying to do this on the cheap I have a set of gm "dimple rods" and stock pistons out of my 525 sc...pistons won't do you much good since the 525 sc's are low low compression but the rods are better than what you have I'm sure...nothing wrong with any of it was just time for me to rebuild and up the power....PM me if you're interested
Other than that...like bill said no way you're going to get parts and labor for a grand unless you buy used and know a guy at a machine shop...I had well over double that just in machine shop labor and I disassembled my old motor myself and took them all the parts....plus mine was a fully running functioning engine just wanted to up the power...don't mean to sh!t on your parade but those are just facts lol
Think I have the stock 525sc cam laying around somewhere too...its a flat tappet not a roller but its a little more than what you have I believe...I'll let this stuff go for next to nothing so lemme know
In your other post you mentioned Tyler Crokket. He has a nice package assembled for a 502Mag.Cam.lifters,springs,fuel pressure regulator,ECM reprogram. You would have to call him to see if it is compatible with your 454. If you start down this road know you need to improve exhaust. Manifolds and risers 3k-4k. With different cam and lifters you need to be able to adjust the valves which means you need screw in studs and guide plates, and new rocker arms. Your stock valve covers won't clear the roller rockers. Will have a clearance issue between valve covers and exhaust depending on what exhaust you use and which tall valve cover you buy. Silent choice? Might have to say goodby to that. Noise restrictions where you boat? Everything you do to add power affects something else. It gets expensive fast. It's all cool if you are prepared for it. Thats why I said rebuild it stock. Feed it gas. Have fun.
there are 4,523,652 454 build threads on here. Search and read, search and read some more, Figure out what exactly you want , then what its going to take to achieve it. As had been said...it's easy to make more power, but then you get to change the fuel system from 3/8 to 1/2 inch, and increase you oil system, bigger lines, new cooler, better oil pump. then you need better exhaust. Screw something up in the recipe and start over. So take some time and read.learn from the mistakes and successes of others.
There is one thing I know. You do one thing and there are three other expenses others you have to do. I was looking for a cam and ecm reprogram but apparently no one makes a 50hp improvement that don't require 10k dollars. I'll build it back stock but I have to ask why do people keep thinking I need new rods? I think I spun a main bearing. Why change the rods if they've live 650 hard hours on this boat. Are they weak?
