XR versus #6
An XR is about 130 pounds depending on the length of the lower. A #6 is 255 pounds. The Bravo HD transom assembly is 78 pounds and the #6 transom assembly is about 250 pounds depending if its a drive line or close coupling.
its 281 lbs if I recall correctly - but then it can be even higher depending on prop used / number of blades and then if I recall that was dry weight. Expect 300 lbs min for a good overall average
