Alignment Tool Recommendation >
Old 10-29-2019 | 11:34 AM
Default Alignment Tool Recommendation
I have a 2005 Formula w/Bravo III's that I'm looking to purchase a drive alignment tool for. The tool from Merc was a little pricey and was looking at
something like this something like this
or similar. Any thoughts for a DIY'er?
afratki is offline
Old 10-29-2019 | 12:18 PM
Oso member whoya he all
so sells them on ebay
phragle is offline
Old 10-29-2019 | 12:28 PM
F-2 Speedy's Avatar
F-2 Speedy is offline
Old 10-29-2019 | 12:43 PM
BUP
Actually Sierra has a good alignment tool or use to. I have one from Sierra, I bought many many years ago. It is very heavy and a very high quality piece. I have a lot others as well Including the Merc OEM and the aftermarkets. Some aftermarket are cheap quality.
With that said I can not verify if Sierra Alignment tool is the same quality as per when I bought mine 20 year ago, Possible still worth the buy. I am not a fan of most Sierra products but YES for the Alignment tool I bought 20 years ago. If it is the same I would buy that in a heartbeat. Also I have the installer mandrel that adapts to the alignment tool. U do not have to drill the hole alignment tool either. U slide it on the tool and makes for a super easy install of the GB. Also the GB is aligned as well using the tool. If in fact your alignment is good from the start.
I check on all that if one needs this set up. The tool and install mandrel.
BUP is offline
Old 10-29-2019 | 04:04 PM
Thanks for the replies everyone. I'll reach out to whoya and check out the one from Sierra.
afratki is offline
Old 10-29-2019 | 09:37 PM
https://www.ebay.com/itm/Boat-Engine...AAAOSwjlVcLoCP
phragle is offline
Old 10-30-2019 | 05:56 AM
FWIW - a machine shop would charge WAY more than the $23 from ebay just in the hourly shop rate to put the bar in the lathe much less cut it down to profile
speicher lane is offline
Old 10-30-2019 | 07:35 AM
Shoot me a message at [email protected].
whoya is offline
Old 10-30-2019 | 08:56 AM
Active Streak: 30 Days
Bought mine years ago at Mercstuff.com The actual business is or was Precision Services Inc. Shelby Township, MI 586-739-4782. Bought stuff from them just this past Summer for my outdrives.
Helmwurst is offline
