496 Mag: Temp Sensor vs Temp Sender
Relative to 496 Mag
1. What are the specifics regarding the Temperature SENSOR (#7) 805218T versus the Temperature SENDER (#8) 806490T?
2. Electrically, where does each connect, and what is the difference in information they provide?
Thanks Ryan00TJ.
I believe you are correct since the SENDER is nearest the thermostat and it makes sense to gauge the water temperature at that juncture. I'll check for continuity from that point to the dash gauge to be certain.
