Best Combo?  X upper w/XR Lower? >
Old 12-10-2019 | 04:18 PM
Default Best Combo? X upper w/XR Lower?
Blew a drive at the end of the season and am looking at my options. Will be moving up to 500 EFI's as well, from 502's - on a Formula 353 Fastech. Bo boxes, just basic bravo ones on the back w/Latham.
Currently have a Bravo with ZX gears and std lower.
With the xtra power being added, what is the best all-around option without going crazy on upgrades?
Was planning on an XZ/X Upper with either upgraded (to xr lower gear set) or new XR lowers (they seem to be the same cost).
Mechanics told me this was best, but in speaking to an OSO reseller - he said to stay with a stock lower to be the weak link and save the upper.
My drive blew when a anchor rope wrapped around it.
snowrunner is offline
Old 12-10-2019 | 04:40 PM
XZ drive is an x upper, with an Xr lower.
Unlimited jd is offline
Old 12-10-2019 | 04:47 PM
F-2 Speedy's Avatar
seems like something else may of been wrong, loosing a drive with a bit over 400 hp
F-2 Speedy is offline
Old 12-10-2019 | 04:48 PM
Was planning on an XZ/X Upper with either upgraded or new XR lowers (they seem to be the same cost).
Yes - anchor line did it in
Old 12-10-2019 | 04:53 PM
got it, xz's are no longer available new - but is likely the best solution in my uneducated opinion
Old 12-11-2019 | 01:20 AM
The upper is the weak link in a Bravo. I would just go with Bravo X drives which are an XZ upper with regular bravo lower.
Griff is offline
Old 12-11-2019 | 04:29 AM
My '08 353 came with 525's and XR's with drive showers. I would think Formula installed the most robust Bravo set up they could. Why do something different?
Apexwarrior is online now
Old 12-11-2019 | 12:58 PM
Regular Bravo's and XZ's were used with 500EFI package. The XR's are marginally stronger than an XZ.
Reasons not to use XR's are lack of longevity for the upper gear sets and cost. An XR costs about 50% more.
Griff is offline
Old 12-12-2019 | 04:05 AM
Thanks for the info. I did not realize the cost differential. Also, how could they be stronger, but lack longevity as compared to the XZ's? Is the best combo then an XZ upper and an XR lower as indicated in an earlier post?
Old 12-12-2019 | 05:21 AM
The XZ drive is made up of the X upper and XR lower.
i thought the XR upper had some other improvements over the X upper not related to the gears. I’ve spoken to at least 5 drive builders this week, only 1 indicated to goto XR’s. 3 said to stick with Bravo lowers.
My Port drive is intact, It’s got the X gears, but the original bravo tower design. So may pull it and sell.
