How do you KILL a momosa tree?? >
Old 11-07-2002 | 01:28 PM
Strip Poker 388's Avatar
Rob
Default How do you KILL a momosa tree??
My neighbors momosa tree hangs over in my yard and driveway . have little momosa trees sprouting up everywhere , drops sap and seeds on cars and boat. i have tried rock salt , round up straight, a brush killer that was supose to be stronger than round up, 2 gallons of muradic acid, the blue stuff you put in holding tanks, nothing has worked .it is about 2 foot in dia, she want let me cut it down. am trying to kill it so she will cut it down.she is a good neighbor putting up with all the noise of boat and race cars and partys.have to becarefull not to be to obvious. please tell me how else i can murder this tree.
Strip Poker 388 is offline
Old 11-07-2002 | 01:36 PM
Ron P's Avatar
Enjoy the show
92 octane gas.
Ron P is offline
Old 11-07-2002 | 01:40 PM
Rob
the fire department might get there to quick.and smell gas?
Old 11-07-2002 | 01:42 PM
CigDaze's Avatar
Aircraft Paint Stripper works great(The thick gel stuff).
A gallon would do it!
Bromide tablets work, too! Used for swimming pool maintenance.
CigDaze is offline
Old 11-07-2002 | 01:51 PM
seanclong's Avatar
Did I read correctly? Two feet in diameter? That's pretty fat. Make sure you don't kill it and then have it fall on your boat. That, I'm sure, will cause a lot more damage than sap!
Safety aside, if you want to kill a big tree you just need to girdle it by cutting through the bark to the fiber all the way around trunk. About an inch or two deep depending on the tree. This stops the tree's ability to transfer nutrients from the leaves to the roots and vice-versa -- eventually the tree dies (just make sure no one is hugging it at the time ).
seanclong is offline
Old 11-07-2002 | 01:54 PM
JUSTONCE's Avatar
RON P's idea and matches
JUSTONCE is offline
Old 11-07-2002 | 02:17 PM
IDRPSTF's Avatar
Ask your closest farmer for a little 2-4-D. Spinkle about a Coke Cap full around the tree. NO NOT PUT ANY MORE THAN THAT. If you need to thin it to make it all the way around the tree. Use Diesel as a thinner. Do Not get any on your shoes. And Do Not do this on a windy day. Trust Me it will work.
I learned more form Crop Dusting than I should have!!!
IDRPSTF is offline
Old 11-07-2002 | 02:18 PM
bajadude's Avatar
Don't know much about 'em. Up here we usually just drink 'em (never knew they came from trees)
bajadude is offline
Old 11-07-2002 | 02:25 PM
ChrisK's Avatar
Moderator
OK the question I have is what the heck is 2-4-D??? sounds like some BAAAAAAADDDDDDDD stuff! You cut it with diesel?? damn...
ChrisK is offline
Old 11-07-2002 | 02:27 PM
283CHECK
Turdon will kill the saplings and if you are able to pinatrate the outer bark migth kill the tree also. You may also just try to squirt it onto the leaves and see if they transfer it into the root system.
